Help needed for definition query syntax to trim off leading 0s in text field.
3744
05-20-2020 10:01 AM
by Anonymous User
Not applicable
Hi. I keep getting errors - This is the syntax directly from ESRI:
TRIM(BOTH | LEADING | TRAILING trim_character FROM string_exp)
I have tried:
TRIM(LEADING '0' FROM "TRAIL_NO")
TRIM(LEADING '0' FROM '0%')
both of these error with
Invalid SQL syntax [ORA-00920: invalid relational operator]
I have also tried many other iterations and have received errors such as missing expression, etc.
What is the correct syntax to remove leading 0s from a text field?  Please help, thanks!!
Also odd - one of the errors showed [STATE_ID = 27] and I do not have a state id field in my attribute table.
Thanks!!!!
Bo_King
Esri Alum
Hi Justine
I can only point you to the Help page, and since you've tried that, I am going move this post over to the Mapping page where you will hopefully find an answer.
Regards,
Bo
#sql query builder#sql functions#sql statement#trim#layerquery
MichaelTownshend
Good Afternoon,
Have you found a resolution to this?  I am only finding the same syntax documentation as you noted above.  I have not found any working examples of how to use TRIM as all instances of the question I've found in the Esri Community pages have been left unanswered.
StevenTouzel
Hello Justine, I think the problem with your query is that it needs a SQL operator like (=, <, >,...). Your TRIM expression looks fine. Here's an example that'll return all rows with an empty OWNER_NAME after the leading and trailing white space is removed:
TRIM(BOTH ' ' FROM OWNER_NAME) = ''
However, if you wanted to recalculate a field and remove the leading '0' you could use python like this:
def removezero(field):
    if (field[0] == "0"):
        return field[1:]
    else:
        return(field)
JMCM
Hello, I know this thread is 4 years old, but I wanted to help future users who found this using Google search like I did.
I found the correct ArcGIS SQL syntax to be TRIM(LEADING '0' FROM TRAIL_NO) (no double quotes around the string expression variable). However, on my end, I still got an error after that.
The Python lstrip function works to remove a leading character, but I assume if you're using SQL in the first place, you want to not use Python (which is slower). I got around this by definition querying/filtering the table first so that it doesn't iterate over unnecessary rows.
Finally, for my purpose, I ended up using the Ctrl + F (find and replace) feature instead. One needs to be careful with this function, but if it applies to your situation, it works *fast*.
