specifiying script output as input to Minimum Bounding Geom in model builder
1192
08-30-2011 10:10 AM
PeteVitt
Hi - I cant seem to specify the location of my script output (shapefile) as an input to the minimum bounding geometry tool in model builder. I've tried double clicking on the output parameter in my model, but the ability to select a location is disabled.  Is there some other way to specify?  When I run the model it gives me an Error 000735 Input Features: Value is required
when I run the script outside the mode it generates the shapefile
attached are screen shots of the model, error, and the disabled interface for specifying location when you double click.
Pete
PeteVitt
ESRI support helped to move the Minimum Bounding Geom tool to the Python script.  With everything in the script the model works
Pete
