Scale Dependent Renderer doesn't work
1124
05-27-2010 11:56 PM
by Anonymous User
Not applicable
Original User: Nordberg1983
Hi all!
I have following issue:
I have a point feature class which I want to thin out scale dependently. For that I'm using the class IScaleDependentRenderer.
Please check the code below. The problem is that I don't see any symbols on the map after running that piece of code.
Any ideas?
Thanks!!!
            IFeatureLayer layer = _selectedLayer as IFeatureLayer;
            IScaleDependentRenderer renderer = new ScaleDependentRendererClass();
            List<double> breaks = new List<double>();
            breaks.Add(500.0);
            breaks.Add(1000.0);
            breaks.Add(2000.0);
            breaks.Add(5000.0);
            IGeoFeatureLayer geoFeatureLayer;
            geoFeatureLayer = (IGeoFeatureLayer)layer;
            List<int> frequencySteps = _frequencySteps;
                for (int i = 0; i < frequencySteps.Count; i++)
                    IFeatureCursor featureCursor = pFeatureClass.Search(null, false);
                    int sum = 1;
                    int freq = frequencySteps;
                    IFeature feature = featureCursor.NextFeature();
                    IFeatureIDSet exclusionSet = new FeatureIDSetClass();
                    ISimpleRenderer sRenderer = new SimpleRendererClass();
                    ISimpleMarkerSymbol sym = new SimpleMarkerSymbolClass();
                    sym.Style = esriSimpleMarkerStyle.esriSMSCircle;
                    sym.Size = 30;
                    sRenderer.Symbol = (ISymbol)sym;
                    IFeatureRenderer fRenderer = (IFeatureRenderer)sRenderer;
                    while (feature != null)
                        if (sum == freq)
                            sum = 1;
                        else
                            exclusionSet.Add(feature.OID);
                        sum++;
                    fRenderer.ExclusionSet = exclusionSet;
                    renderer.AddRenderer(fRenderer);
                    renderer.set_Break(i, breaks);
                    System.Runtime.InteropServices.Marshal.ReleaseComObject(featureCursor);
                    geoFeatureLayer.Renderer = (IFeatureRenderer)renderer;
by Anonymous User
Not applicable
No similar problems in the ESRI world???
