Select By Attributes
773
05-31-2010 04:11 AM
NehayaArabeiat
Hi All,
I want to select features from feature layer depends on a query filter and then zoom to selected features, How can I do that , can you help please??
ThavitinaiduGulivindala
Cast IFeatureLayer object to IFeatureSelection inerface. Use IFeatureSelection interface to select features using query filter.
http://edndoc.esri.com/arcobjects/9.2/ComponentHelp/esriCarto/IFeatureSelection_SelectFeatures.htm
Here is the way to run the built-in ArcMap Command. Hence u can run 'Zoom To Selected Features' command in the same way.
http://edndoc.esri.com/arcobjects/9.2/NET/858a508c-b771-467c-81e6-c6aa72d88f9c.htm
