Buffer without overlap or slivers
5084
09-04-2014 01:18 PM
DavidLehrke
I'm trying to automatically or quickly create a polygon feature created by buffering a line feature.  These line feature run in connected segments, the issue is I need these polygons to extend/trim so that there is no overlap or slivers between each polygon.
Notice the sliver/overlap at '61' or the gap/overlap at '62'  These are the issues I'm trying to avoid.
Another way to look at it is I want a shape similar to that created when using Copy Parallel except I want Polygons not lines.
Any help would be appreciated, thanks.
Tags (1)
AdCulver
If all your buffers have the same distance you could add buffers to the points and dissolve the points and line buffers together.
