JQuery Basemaps title not showing. How can I fix that.
1915
09-03-2014 01:42 PM
AlexGole
Hi all,
I am trying to get my basemaps titles to show in JQuery. I am really not sure why It is not currently showing.
Here is my script.
Any ideas are welcome!
Thank you,
Alex
KellyHutchins
Esri Notable Contributor
Looks like the bootstrapmap.css file has a rule that turns off the label display. If you comment out this rule the labels will display for the base map gallery.
LIne 234 of bootstrapmap.css
.esriBasemapGalleryLabelContainer{
     display:none;
KellyHutchins
     display:none;
AlexGole
I got rid of this css line but did not get any labels.
KellyHutchins
It looks like your app is referencing the bootstrapmap.css file on esri.github. If you don't have access to this file you can make a local copy, make the update then update the link in map-widget.html to point to your local copy.
http://esri.github.io/bootstrap-map-js/src/css/bootstrapmap.css
Alternatively you can add this rule to the style section of map-widget.html:
     display:block;
      color: #fff;
AlexGole
Got it! Thank you!
