Alter point field based on another layer
4108
08-29-2014 09:38 AM
RobertHogwood
I performed a network analysis to create a series of polygons based on distances (100, 200, 300m etc) around facilities for a project I'm working on. I also have population weighted centroids (point data) that I want to be given a value for a new field based on which polygon they fall under. For example, all centroids which fall in the 500m polygon from a facility would be given a 'poor' value for Access.
Is there an easy way to do this?
Thank you.
JorgeOrellana
Spatial Join should do the trick. First assign your polygons the categories that you need (i.e. Poor, Fair, Good, Excellent etc). Once you have that set your Target Features to  your points and your Join Features would be your polygons. Your out put will now have the points with the values that you assigned the polygon they are in.
JorgeOrellana
RobertHogwood
Thank you for the reply. Before I test this I just want to ask one more thing - is it possible to give points that don't fall within any of the polygons a value of 'no access' for example?
RobertHogwood
I tried it out and it seems that all points which do not fall within the polygons are deleted. Is it perhaps possible to give all blank/null space on the shapefile a specific value?
RobertHogwood
I found a way to accomplish the task by creating a new shapefile, drawing a shape and clipping it to the area I'm using. Then I used the erase tool to remove the exisiting polygons from the newly created shape, leaving only the previously blank areas filled by the shape. I appended it to the polygons.
Thanks for the help
