Track interval to line tool
2823
08-28-2014 11:41 PM
Pui_Suen_JaneLee
Hi, I use the tool 'Track interval to line' in order to calculate the speed of movement between two sets of points (with xyz coordinates), but when I open the attribute table of the newly created feature, the distances are inaccurately calculated which also affect the values of speed, can anyone help me with this? Many Thanks!
DarrenWiens2
MVP Honored Contributor
Is the issue that it calculates 3D distance when you want 2D distance, or vice versa? Or are the values completely wrong (e.g. using decimal degrees rather than meters)?
