Add Subtype Doesn't Work
1797
08-28-2014 12:29 PM
JordanParfitt
I've tried using Model Builder, The Toolbox, and Python, nothing works.
>>> arcpy.AddSubtype_management('ARG.ABAN_Conduit_Valve', '2', 'asdf')
<Result 'Database Connections\\[email protected]\\ARG.ABANDONED\\ARG.ABAN_Conduit_Valve'>
It say's everything ran successful. When I add in the subtype manually (properties, subtype, enter in subtype) it works fine. I have to add the same subtypes to 12 tables and I'm trying to avoid manually entering them.
What am I doing wrong?
JordanParfitt
XanderBakker
Esri Esteemed Contributor
The help mentions some requirements (ArcGIS Help 10.1 ) but I suppose you have already checked those.
The page also shows some examples in which the sub type field is explicitly set. What happens if you do this?
