Buffer around all geometries
2797
08-22-2014 04:58 PM
DanielWebb2
I’m looking to create one buffer around multiple graphics.
The user clicks the desired polygons, which creates graphics matching the geometry of the polygons. After certain ones are picked I want to buffer around all of those with the same shape they all have together.  Below is the code I’m trying for the buffer.
It always break on gsvc.buffer(params, showBuffer); which makes me think there’s a problem with the params.
var geom = new Graphic();
geom = graphicsLayer.graphics;
var selectedGeom = graphicsUtils.getGeometries(geom);
var bufferDist = Math.floor(dom.byId("txtBufferDist").value);
var params = new BufferParameters();
params.geometries = [selectedGeom];
params.distances = [bufferDist];
params.unit = GeometryService.UNIT_FOOT;
params.outSpatialReference = bcMap.spatialReference;
function showBuffer(){
     //Code
HOWEVER, if I use graphicsUtils.graphicsExtent instead of graphicsUtils.getGeometries it works. But I don’t want a square every time. I want the buffer to follow the outline shape as seen in yellow.
Thanks for any help.
RobertScheitlin__GISP
Daniel,
  So it looks like your issue is that graphicUtil.getGeometries returns an array and you then are putting that array inside another array here:
Try:
params.geometries = selectedGeom;
You also are start the geom var as a Graphics and then overwrite it with an array of Graphics:
This is no big deal as you are overwriting it but there is no need to start it as a Graphic and then set it to an Array. This would make more sense:
var graphics = graphicsLayer.graphics;
var selectedGeoms = graphicsUtils.getGeometries(graphics);
Daniel,
Try:
DanielWebb2
Thanks a ton! That basically got it.  Now it makes a graphic around each polygon.  This at least gets past my wall gives me something else to look into.  I’m hoping to get one single graphic as a buffer.
Thanks again.
Daniel,
  for that you just need to set the unionResults to true for the BufferParameters
DanielWebb2
You rock!  It was so simple!  Now I feel dumb for missing that property.  I was trying to figure how to make esri/dijit/editing/Union or esri/dijit/analysis/MergeLayers work.
Thanks for your help.
