Feature service token issues with Ajax
2390
08-21-2014 02:00 PM
maximcouton
I have published a Feature Service in arcgis online ,
I order to access it , It requires a Token .  Using the browser for the first time the pop asks me tto enter atht token, all thing goes fine.
Using ajax I have no idea how to use that token .
Thanks for help.
maximcouton
I get the error :
  1. message: "Token Required"
OwenEarley
If you are using the ESRI JS API - check out the Token based authentication section on the secure services help section. You may need to use the Identity Manager so check out the samples.
If you are using ajax with the REST API the token should be added to the request URL. See the ArcGIS REST API‌ page for more information.
