Loading image won't stop
1723
08-20-2014 08:56 AM
MayJeff
Here is my code:
Edit fiddle - JSFiddle
The loading image will start loading when map is loading but after map is loaded the loading image won't stop.  Can you tell me where I add to modify the code?
Thanks.
JakeSkinner
Esri Esteemed Contributor
Hi May,
You will need to add the esri.domUtils class to your code.  Also, you will need to use the 'update-start' and 'update-end' events.  Ex:
<!DOCTYPE html>
<html>
  <head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Simple Map</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      body {
        background-color: #FFF;
        overflow: hidden;
        font-family: "Trebuchet MS";
    </style>
     <script src="http://js.arcgis.com/3.10/"></script>
    <script>
     require([
        "esri/map", "esri/layers/ArcGISDynamicMapServiceLayer",
        "dojo/on",
        "dojo/dom",
        "esri/domUtils",
        "dojo/domReady!"
      ], function(
        Map, ArcGISDynamicMapServiceLayer, on, dom, domUtils
          var map;
    var loading, loadingIconShow, loadingIconHide; //loading #1
       loading = dom.byId("loadingImg");  //loading image. id
        map = new esri.Map("map", {
          basemap: "topo",
          center: [117.773, 28.498],
          zoom: 6
        loadingIconShow = map.on("update-start", showLoading);
        loadingIconHide = map.on("update-end", hideLoading);
        //Takes a URL to a non cached map service.
        var dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/MapSer...");
        dynamicMapServiceLayer.setOpacity(0.4);
        map.addLayer(dynamicMapServiceLayer);
    function showLoading(){
        domUtils.show(loading);
        map.disableMapNavigation();
        map.hideZoomSlider();
    function hideLoading(error){
      domUtils.hide(loading);
      map.enableMapNavigation();
      map.showZoomSlider();
    </script>
  </head>
  <body>
    <div id="map">
  <img id="loadingImg" src="images/loading.gif" style="position:absolute; right:512px; top:256px; z-index:100;" /> <!--loading #5-->
  </div>
  </body>
</html>
JakeSkinner
Hi May,
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #map {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      body {
        overflow: hidden;
    </style>
    <script>
     require([
        "dojo/on",
        "dojo/dom",
        "esri/domUtils",
        "dojo/domReady!"
      ], function(
          var map;
          basemap: "topo",
          zoom: 6
    </script>
  </head>
  <body>
    <div id="map">
  </div>
  </body>
</html>
JohnGrayson
Esri Alum
You are missing a require for "esri/domUtils":
MayJeff
Thank you all very much.  It works.
