How to create a Polygon from a single point
17913
20
08-18-2014 12:58 PM
JoshV
I'm trying to programmatically figure out how to create a polygon feature using just a single point.  If my spatial reference is Web Mercator WGS84 and I want a 1 Meter by 2 Meter Polygon, how can I go about this?  The point can be any Latitude Longitude, I just need to get an idea if this can be done or not. Thanks
DarrenWiens2
West coordinate = KnownX - 0.5*width
East coordinate = KnownX + 0.5*width
North coordinate = KnownY + 0.5*height
South coordinate = KnownY - 0.5*height
DanPatterson_Retired
Why not use a projected coordinate system?  What is the orientation of the rectangle that you need? Why is a rectangle needed and not a circle (ie a buffer)? Is this a grid pattern that you are trying to produce (ie Fishnet) over an area or for discrete points?  Any further criteria would be useful
JoshV
Hi Dan,  A Projected Coordinate system is fine if thats easier.  I'm actually working with State Plane Nad 83 Arkansas North Feet.  It needs to be rectangular, otherwise I could do this by manipulating the point symbology.  The angles of each corner can be 90 degrees but for simplicity purposes the rectangle dimensions can be 10 Feet by 20 Feet if projected then.  Thoughts?
If this is purely a symbology issue, I certainly wouldn't go to the trouble of trying to create rectangular features.  There are some links in the help files on symbols and creating symbols
General comments
Creating your own
JoshV
Hi Dan.  A symbol will probably not work because I have to assume the user can zoom in at any level they choose to.  I'm actually trying to create a graphic (polygon graphic with corners) in silverlight but I wanted to prove this up in Desktop first.  So is this not possible at all? If its too difficult to produce a polygon could a line be derived?
DarrenWiens2
If you really want to get into it, I believe you're looking for "Writing Geometries" using Python, but as Dan indicates this is likely overkill, especially if you are not proficient in Python.
JoshV
Hi Darren, those examples look like a coordinates have to passed in though.  Is there not a way to calculate where the 4 corners could be from the specfied point?  I realize that the graphic or feature wd display in different orientations but if I producgraphic from this, it would at least have the correct dimensions and my template has the ability to rotate graphics.
If you know the coordinates of the center of the feature, you can calculate the coordinates of four corners using simple math given you know the width and height of the feature you want to create...however, this would have to be done for each feature and they would not be scaleable as you zoom in and out.  So the question becomes, how important is the actual size whether it be a feature or simply a symbol?
JoshV
Hi Dan, yes could you give me an example of this?  So in-essence, whenever a user clicks the map and has this process active, what would this calculation look like knowing the XY from the mouse click?  It is important that the size of the new polygon feature matches the map (size = 10 Feet by 20 Feet).  Thoughts?
DarrenWiens2
