max database size for offline sync?
5163
08-15-2014 08:31 AM
MattCooper
Is there a maximum size allowed for sync'ing with the SDK? I realize it might not be a great idea to try and pull down a 3GB geodatabase, but just curious if there is a hard limit set in the SDK.  We've noticed that if the GDB gets too large (somewhere around 1 GB) that the sync process fails and the geodatabase won't be downloaded. This is an issue if the GDB grows in size during field collection and sync'ing and we need to install the app on a new device and it needs to download the initial gdb which is now well over the limit that the SDK will download successfully unless we apply a filter to limit the features/attachments returned.
The error that is returned by the SDK is:The requested URL was not found on this server.
The error that shows up in the event viewer on the server is: Overflow or underflow in the arithmetic operation. Process information references the ArcGIS Web Adapter.
I can see the geodatabase at the exact location the URL references, so perhaps this is an issue with our IIS config or web adapter config for larger files?
Matt
cc: Michael Davis
Tags (3)
DiveshGoyal
There isn't a hard limit set in the SDK, for either generating the initial geodatabase, or for syncing updates to it.
MichaelDavis3
If that is the case what could be causing the error Matt Cooper‌ mentioned in his post?  Could it be an issue with ArcGIS Server not being able to deliver files larger than a certain size?
DiveshGoyal
Yes, that is a possibility, although the server should be capable of handling such files. Have you tried downloading the file using the URL in a browser? Does it also error out?
