Layer list
4065
08-15-2014 09:43 AM
KeisukeNozaki
Here is a layer list widget provided by WebApp Builder Beta.
It is not always easy to turn on and off on mobile devices.
Is there a way to enlarge a checkbox?
Or can I have a layer turned on or off by touching layer name?
I appreciate your advice.
RobertScheitlin__GISP
Keisuke,
   The check box that the layer list widget uses is sized based on the jimu.css file and the size of the images/checked.png. So yes you could increase the size of the images/checked.png (currently 14x14px) and then adjust the height and width of the .jimu-checkbox .checkbox in the css.
KeisukeNozaki
Thank you.
But it did not work as I expected.
How hard is it to turn on or off a layer by touching layer name?
Keisuke,
  Ok, in the LayerListView.js you need to add a line and a new function.
find this line:
this.own(on(ckSelect.domNode, 'click', lang.hitch(this, this._onCkSelectNodeClick, layerInfo, ckSelect)));
and add this one below it:
this.own(on(divLabel, 'click', lang.hitch(this, this._onLabelNodeClick, layerInfo, ckSelect)));
Then add this new function:
     _onLabelNodeClick: function(layerInfo, ckSelect, evt) {
      if (ckSelect.checked) {
        ckSelect.setValue(false);
        layerInfo.setTopLayerVisible(false);
      } else {
        ckSelect.setValue(true);
        layerInfo.setTopLayerVisible(true);
      evt.stopPropagation();
