Cannot snap point to measure or split feature (Editor) in ArcGIS server 10.0
6688
9
08-14-2014 06:16 PM
DungNgo
This is my video
RickeyFight
Do you have a Arcgis online account? If you do then you can make better web apps and they are really easy.
Do you have a Server set up?
https://www.arcgis.com/home/signin.html
DungNgo
Please, help me!
RickeyFight
Is this a web app or ArcView?
If arcView you need to change the snapping settings in Editor.
If web app make sure your MXD that your service is running off of has that layer select-able and that your tolerance is not too large.
DungNgo
This is a web app.Can you more specific instructions? Thank you so much!
RickeyFight
Without you posting some of your code it will be hard.
does your code use the snappingmaneger?
snappingmanager-amd | API Reference | ArcGIS API for JavaScript
DungNgo
No, it isn't. I don't know to use ArcGIS API for JavaScript
RickeyFight
How did you make this webapp?
DungNgo
RickeyFight
DungNgo
Thank you! I'll try it!
