This is my video
Do you have a Arcgis online account? If you do then you can make better web apps and they are really easy.
Do you have a Server set up?
Is this a web app or ArcView?
If arcView you need to change the snapping settings in Editor.
If web app make sure your MXD that your service is running off of has that layer select-able and that your tolerance is not too large.
This is a web app.Can you more specific instructions? Thank you so much!
Without you posting some of your code it will be hard.
does your code use the snappingmaneger?
snappingmanager-amd | API Reference | ArcGIS API for JavaScript
No, it isn't. I don't know to use ArcGIS API for JavaScript
How did you make this webapp?
Thank you! I'll try it! ![]()
