Build Errors with Traffic Data
4387
08-13-2014 12:17 PM
ToddFagin
Greetings all,
I am trying to build a Network Dataset with historic traffic data. (The traffic data are actually completely fictitious designed solely for the purposes of trying to learn how to configure a network dataset).
The best I can tell both my tables and feature class are configured properly (with the exception of EdgeFCID--I have not idea how to determine the feature class ID; I only have one feature class participating in the network, though, so I went with 1 since that was the value the tutorial data used). When I build the dataset, I receive the following message: SourceName: Streets_DailyProfiles, ObjectID: 6, Network edge not found with positions 0.000000 to 1.000000.
It then replicates this error for every ObjectID for which I have configured the daily profiles.
Any suggestions on why this is and how to fix it would be greatly appreciated.
Many thanks in advance,
Todd
AsafBen-Ari
Hi Todd,
The Feature Class ID is automatically defined when you import the streets FC into the Feature Dataset, and it is often different from 1.
If you have a "no turn" FC you can find the FCID over there (since they both relate to the same streets FC).
As far as I know, the only other way to find out the FCID is through a code.
Asaf.
AsafBen-Ari
Another option is to use this "Dummy" data:
http://www.arcgis.com/home/item.html?id=ab6d78835f6f4fb991accbafdb3ed41a
Asaf.
ToddFagin
Thank you for the reply. I have been out of the office and haven’t been able to give this a try yet. I will first thing tomorrow.
Again, many thanks.
ToddFagin
I found the answer to my question about the FeatureClassID. It is actually easy to determine once you know where to look:
http://resources.arcgis.com/en/help/main/10.1/index.html#//0047000001rz000000
Knowing this fixed my problems.
Many thanks.
Todd Fagin
Oklahoma Natural Heritage Inventory/
Department of Geography and Environmental Sustainability
