Feature dataset limit?
1727
08-10-2014 09:25 PM
JamesPreston
Is there a limit on the number of feature datasets that I can create in a file geodatabase? Does this at some point cause performance issues, or is there a hard limit?
I have a file geodatabase in which each month I receive some data that is placed in a feature dataset named after that month. This in theory will be happening in perpetuity. Is there another method of data management that I should be investigating?
Thanks in advance.
DanPatterson_Retired
From the help files
General discussion including Personal gdb
File Geodatabase
Enterprise Geodatabase
which should give you a starting point for consideration
From the help files
File Geodatabase
JamesPreston
Thanks, Dan.
I read through the help files and have come to the conclusion that there should be no limit to the number of feature datasets that I can have sitting in a file geodatabase. However, it is never explicitly addressed. I guess I just wanted some reassurance that I would not run into difficulties in the future. But given the volumes of data that the geodatabases are designed to handle, I would assume that multiple feature datasets would not cause issues.
ahmedzeidan
Farther to Dan's answer, i would like to share with you a very old article entitled "The Top Nine Reasons to use a File Geodatabase" which could help you.
http://www.esri.com/~/media/Files/Pdfs/news/arcuser/0309/files/9reasons.pdf
