Multiple layer attribute inspector
4140
08-10-2014 11:12 AM
williamcarr
I'm trying to get the attribute inspector to work with multiple layers, but I'm unsure of how to go about the layInfos.
var layerInfos = [{
           'featureLayer': petroFieldsFL,
            'showAttachments': false,
            'isEditable': true,
            'fieldInfos': [
              {'fieldName': 'SERVICE_ID', 'isEditable':true, 'tooltip': 'Current Status', 'label':'Status:'}
          var attInspector = new AttributeInspector({
            layerInfos:layerInfos
          }, domConstruct.create("div"));
Do I need to create an attribute inspector for each layer?
OwenEarley
The documentation states that layerInfos is an object array so your should be able to pass them in using a modified version of your code:
var layerInfos = [
          'isEditable': true,
          'fieldInfos': [ {'fieldName': 'SERVICE_ID', 'isEditable':true, 'tooltip': 'Current Status', 'label':'Status:'} ]
          'featureLayer': otherFL,
          'isEditable': true,
          'fieldInfos': [ {'fieldName': 'OTHER_ID', 'isEditable':true, 'tooltip': 'Some Tooltip', 'label':'Some Label:'} ]
Also, this Multiple Attribute Inspectors | ArcGIS API for JavaScript sample connects each layer to a new attribute inspector dynamically which is possibly an alternate approach to your problem.
Owen
Spatial XP
OwenEarley
var layerInfos = [
          'isEditable': true,
          'isEditable': true,
Owen
Spatial XP
williamcarr
Paydirt! Thanks Owen.
williamcarr
Owen,
      I ran into a couple other issues with the apply edits passing. Not sure how but only select layers are passing(usually the first one listed), or if multiple points are selected at a time. I think it is the loading of layers into initSelectToolbar array.
The rest of the code is just like the sample, but I think these are the trouble areas. It throws a TypeError: updateFeature is undefined upon trying to apply edits with the save button.
Could you take another look to see how I am failing at life?
Thanks in advance.
        function initSelectToolbar(evt) {
          var asdf = evt.layers[0].layer;
          var selectQuery = new Query();
          map.on("click", function(evt) {
              var selectionQuery = new esri.tasks.Query();
        var tol = map.extent.getWidth()/map.width * 5;
        var x = evt.mapPoint.x;
        var y = evt.mapPoint.y;
        var queryExtent = new esri.geometry.Extent(x-tol,y-tol,x+tol,y+tol,evt.mapPoint.spatialReference);
        selectionQuery.geometry = queryExtent;
            asdf.selectFeatures(selectionQuery, FeatureLayer.SELECTION_NEW, function(features) {
               //store the current feature
                updateFeature = features[0]; console.log("adf");
                map.infoWindow.setTitle(features[0].getLayer().name); console.log("adf");
                map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint)); console.log("adf");
          var layerInfos = [{
            'isEditable': true
          { 'featureLayer': petroFieldsFL1,
            'isEditable': true}];
          //add a save button next to the delete button
          var saveButton = new Button({ label: "Save", "class": "saveButton"});
          domConstruct.place(saveButton.domNode, attInspector.deleteBtn.domNode, "after");
          saveButton.on("click", function(){
            updateFeature.getLayer().applyEdits(null, [updateFeature], null);
          attInspector.on("attribute-change", function(evt) {
            //store the updates to apply when the save button is clicked
            updateFeature.attributes[evt.fieldName] = evt.fieldValue;
          attInspector.on("next", function(evt) {
            updateFeature = evt.feature;
            console.log("Next " + updateFeature.attributes.objectid);
          attInspector.on("delete", function(evt){
            evt.feature.getLayer().applyEdits(null,null,[feature]);
            map.infoWindow.hide();
          map.infoWindow.setContent(attInspector.domNode);
          map.infoWindow.resize(350, 240);
