Map Service Spatial Reference Incorrect
4533
15
08-07-2014 10:25 AM
JoshObrecht
I am trying to add a map service into my application. The application has a spatial reference of 102100, as does the map service on the server. However when I add the service, it gets changed to 4326. Has anyone seen this issue previously and can give some insight?
RobertScheitlin__GISP
Josh,
   it sound like you need to wait for the layer to load before you set the maps extent.
Josh,
   How exactly do you know that it gets changed to 4326?
JoshObrecht
I put in an alert to call the spatial reference of the layer. It tells me 4326.
Josh,
   This seems pretty strange... Can you share your code?
JoshObrecht
Not sure how well this will work. I can't give actual links since the services are not public yet.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
  <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
  <!--The viewport meta tag is used to improve the presentation and behavior of the samples
  on iOS devices-->
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
  <title>EDF Land-Use Viewer</title>
  <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dijit/themes/claro/claro.css" />
  <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
  <link rel="stylesheet" type="text/css" href="../st30_huc/agsjs/css/agsjs.css" />
  <link rel="stylesheet" type="text/css" href="css/layout.css"/>
  <style>
  html, body {
  height: 100%;
  width: 100%;
  margin: 0;
  padding: 0;
  .esriScalebar {
  padding: 20px 20px;
  #map {
  padding: 0;
  </style>
  <script type="text/javascript">
  var djConfig = {
  parseOnLoad : true,
  paths : {
  //if you want to host on your own server, download and put in folders then use
  // path like:
  agsjs : location.pathname.replace(/\/[^/]+$/, '') + '/../st30_huc/agsjs'
  </script>
  <script src="//js.arcgis.com/3.10/"></script>
  require(["dojo/_base/connect", "dojo/dom", "dojo/parser", "dojo/on", "dojo/_base/Color", "esri/map", "esri/geometry/Extent", "esri/layers/FeatureLayer", "esri/layers/ArcGISTiledMapServiceLayer", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/symbols/SimpleFillSymbol", "esri/renderers/ClassBreaksRenderer", "agsjs/dijit/TOC", "esri/dijit/BasemapToggle", "dijit/layout/BorderContainer", "dijit/layout/TabContainer", "dijit/form/Button", "dijit/layout/ContentPane", "dijit/form/CheckBox", "dijit/dijit", "dojo/fx", "dojo/domReady!"], function(connect, dom, parser, on, Color, Map, Extent, FeatureLayer, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer, SimpleFillSymbol, ClassBreaksRenderer, TOC, BasemapToggle) {
  /*  dojo.require("dijit.dijit"); // optimize: load dijit layer
  dojo.require("dijit.layout.TabContainer");
  dojo.require("dijit.form.Button");
  dojo.require("dijit.form.CheckBox");
  dojo.require("esri.dijit.Legend");
  dojo.require("esri.dijit.BasemapToggle");*/
  var myOnClick_connect, aspf, legend, dynamicLayer;
  var map, toggle;
  function init() {
  var lods = [{
  "level" : 5,
  "resolution" : 4891.96981024998,
  "scale" : 1.8489297737236E7
  "level" : 6,
  "resolution" : 2445.98490512499,
  "scale" : 9244648.868618
  "level" : 7,
  "resolution" : 1222.99245256249,
  "scale" : 4622324.434309
  "level" : 8,
  "resolution" : 611.49622628138,
  "scale" : 2311162.217155
  "level" : 9,
  "resolution" : 305.748113140558,
  "scale" : 1155581.108577
  "level" : 10,
  "resolution" : 152.874056570411,
  "scale" : 577790.554289
  "level" : 11,
  "resolution" : 76.4370282850732,
  "scale" : 288895.277144
  "level" : 12,
  "resolution" : 38.2185141425366,
  "scale" : 144447.638572
  "level" : 13,
  "resolution" : 19.1092570712683,
  "scale" : 72223.819286
  "level" : 14,
  "resolution" : 9.55462853563415,
  "scale" : 36111.909643
  "level" : 15,
  "resolution" : 4.77731426794937,
  "scale" : 18055.954822
  "level" : 16,
  "resolution" : 2.38865713397468,
  "scale" : 9027.977411
  var initialExtent = new esri.geometry.Extent({
  "xmin" : -10829199.684,
  "ymin" : 4415445.069,
  "xmax" : -9713948.365,
  "ymax" : 5868854.92,
  "spatialReference" : {
  "wkid" : 102100
  map = new Map("map", {
  extent : initialExtent,
  lods : lods,
  basemap : "streets"
  var dynamicUrl = "http://localhost/server30/rest/services/edf/MapServer";
  toggle = new BasemapToggle({
  map : map,
  visible : false,
  basemap : "satellite"
  }, "BasemapToggle");
  toggle.startup();
  dynamicLayer = new esri.layers.ArcGISTiledMapServiceLayer(dynamicUrl);
  dojo.connect(map, 'onLayersAddResult', function(results) {
  legend = new TOC({
  map : map,
  layerInfos : [{
  layer : dynamicLayer,
  title : ' '
  }, "legendDiv");
  legend.startup();
  map.addLayers([dynamicLayer]);
  identifyTask = new esri.tasks.IdentifyTask("http://localhost/server30/rest/services/edf/MapServer");
  identifyParams = new esri.tasks.IdentifyParameters();
  identifyParams.tolerance = 3;
  identifyParams.returnGeometry = true;
  identifyParams.layerIds = [2];
  identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
  identifyParams.width = map.width;
  identifyParams.height = map.height;
  var layer = map.getLayer(map.layerIds[0]);
  layer.setVisibility(false);
  dojo.connect(map, "onExtentChange", showExtent);
  dojo.connect(dijit.byId("val1"), "onChange", function(isChecked) {
  if (isChecked) {
  dojo.disconnect(myOnClick_connect);
  dojo.connect(dijit.byId("val2"), "onChange", function(isChecked) {
  if (isChecked) {
  myOnClick_connect = dojo.connect(map, "onClick", doIdentify);
  dojo.connect(dijit.byId("val3"), "onChange", function(isChecked) {
  if (isChecked) {
  function showExtent(extent) {
  if (map.getLevel() > 5) {
  toggle.show();
  layer.setVisibility(true);
  if (aspf) {
  aspf.setVisibility(true);
  } else {
  toggle.hide();
  if (aspf) {
  aspf.setVisibility(false);
  if (map.getLevel() > 4) {
  document.getElementById("active").style.visibility = "visible";
  } else {
  document.getElementById("active").style.visibility = "hidden";
  function doIdentify(evt) {
  if ((dijit.byId("val2").checked && map.getLevel() > 4) || dijit.byId("val3").checked) {
  identifyParams.geometry = evt.mapPoint;
  identifyParams.mapExtent = map.extent;
  identifyTask.execute(identifyParams, function(idResults) {
  addToMap(idResults, evt);
  function addToMap(idResults, evt) {
  var idResult;
  for (var i = 0, il = idResults.length; i < il; i++) {
  idResult = idResults.feature;
  if (dijit.byId("val2").checked) {
  window.open("http://localhost/ST30_EDF_PDF/FB" + idResult.attributes.HUC_12 + ".pdf");
  if (dijit.byId("val3").checked) {
  aspf = new esri.layers.ArcGISDynamicMapServiceLayer("http://localhost/server30/rest/services/acpf/MapServer", {
  visible : true
  } else {
  visible : false
  map.addLayer(aspf);
  legend.layerInfos.splice(1, 0, {
  layer : aspf,
  title : " ",
  autoToggle : false
  legend.refresh();
  dojo.addOnLoad(init);
  </script>
  </head>
  <body class="claro">
  <div id="mainWindow" dojotype="dijit.layout.BorderContainer" design="headline"
  gutters="false" style="width:100%; height:100%;">
  <div id="header" dojotype="dijit.layout.ContentPane" region="top">
  ACPF Land-Use Viewer
  </div>
  <div dojotype="dijit.layout.ContentPane" id="leftPane" region="left">
  <div dojotype="dijit.layout.TabContainer" >
  <div dojotype="dijit.layout.ContentPane" title = "Legend" selected="true">
  <div id="legendDiv"></div>
  <input dojoType="dijit.form.RadioButton" id="val1" name="group1"
  checked="checked" value="nav" type="radio" />
  <label for="val1"> Navigate </label>
  <input dojotype="dijit.form.RadioButton" id="val2"  name="group1"
  value="pdf" type="radio" />
  <label for="val2"> PDFs </label>
  <input dojotype="dijit.form.RadioButton" id="val3"  name="group1"
  value="add" type="radio" />
  <label for="val3"> Populate </label>
  <br />  <br />
  <label id="active" style=" color:Red; font-size:large; visibility:hidden;">PDFs Active</label>
  <br />  <br />
  <label >To use this map:
  <br />  - Use your mouse to Pan and Zoom
  <br />  - Zooming in will activate the PDF downloads, "PDFs Active" note will appear.
  <br />  - Select the PDF button to enable to PDF downloads
  <br />  - Click on a watershed to obtain the PDF
  <br />  - Select the Populate button to enable detailed information
  <br />  - Click on a watershed to bring up extra information </label>
  <br />  <br />
  <div style="width:64px;">
  <div id="BasemapToggle" ></div>
  </div>  </div>  </div>  </div>
  <div id="map" dojotype="dijit.layout.ContentPane" region="center" >
  </div>  </div>
  </body>
</html>
Josh,
So this var dynamicUrl = "http://localhost/server30/rest/services/edf/MapServer"; is a cached map service?
Does it's cached lods matched the ArcGIS Online lods?
JoshObrecht
Correct on both counts.
Josh,
   There are a few funky things in your code probably left over from your upgrade from legacy code to AMD. Also without your CSS I can't tell if your layout is working. Right now with removing your CSS and your code calling your local layer it does not even run without several errors.
JohnGrayson
Esri Alum
1) What is the Spatial Reference of the Map?
2) What is the Spatial Reference of the first layer added to the Map?
Josh,
  Where are you adding that alert? Is it in one of the identify functions? If so then you are just seeing a known bug.
Here is a thread talking about results coming back with wrong WKID.
IdentifyTask + InfoWindow 'Zoomto' button using wrong spatial reference
