How to use defined parameters in a tool ?
10169
14
08-07-2014 04:15 AM
CARMETSandrine
I'm very new at python, and I don't understand how to use the defined parameters in the source code of the tool.
I'm trying to create a tool (with clip and contour tools) who can be used by any user (not specified folders or classes). My script is in attachment.
Can somebody take a look ? :S
XanderBakker
Esri Esteemed Contributor
To get you started, have a look at the code below. Use this script by adding it as a script to a new toolbox.
Define the 5 parameters as explained on line 18 - 22
# Name:        clip_contour.py
# Purpose:     clip raster and create contours
# Author:      Sandrine Carmet
# Created:     08/08/2014
class LicenseError(Exception):
    pass
def main():
    import arcpy
    import os
    # read the parameters
    fc_extent = arcpy.GetParameterAsText(0) # define as featurelayer, filter polygon, direction input
    ras_in = arcpy.GetParameterAsText(1) # define as rasterlayer, direction input
    ras_clip = arcpy.GetParameterAsText(2) # define as raster dataset, direction output
    fc_contour = arcpy.GetParameterAsText(3) # define as featureclass, direction output
    interval = arcpy.GetParameter(4) # define as Double, set min and max range, provide default
    # configuration of contours
    contour_interval = interval # not 4...
    base_contour = 0
    z_factor = 1
    try:
        if arcpy.CheckExtension("3D") == "Available":
            arcpy.CheckOutExtension("3D")
        else:
            # raise exception
            raise LicenseError
        # set in memory workspace
        arcpy.env.workspace = "IN_MEMORY"
        # Determine the extent of the fc
        extent = arcpy.Describe(fc_extent).extent
        ext_txt = "{0} {1} {2} {3}".format(extent.XMin, extent.YMin, extent.XMax, extent.YMax)
        # Clip the raster
        arcpy.Clip_management(ras_in, ext_txt, ras_clip, fc_extent, "#", "ClippingGeometry")
        # Create the contours
        arcpy.Contour_3d(ras_clip, fc_contour, contour_interval, base_contour, z_factor)
        # return license
        arcpy.CheckInExtension("3D")
        # outputs are automatically added to the TOC...
    except LicenseError:
        print("3D Analyst license is unavailable")
    except arcpy.ExecuteError:
        print(arcpy.GetMessages(2))
if __name__ == '__main__':
    main()
Once you run the script successfully, you can go to the Results windows and see the syntax for executing the script.
# Replace a layer/table view name with a path to a dataset (which can be a layer file) or create the layer/table view within the script
# The following inputs are layers or table views: "pols", "DEMsmpro"
arcpy.ClipRasterCreateContours("pols","DEMsmpro","D:/Xander/grd/test_clip","D:/Xander/tmp/test2.gdb/test_contours","50")
You could create another script that simply executes this script or change the script to work with a list of inputs.
Kind regards, Xander
JohannesBierer
InRaster = arcpy.GetParameterAsText(0)
Output = arcpy.GetParameterAsText(1)
CARMETSandrine
humm this is not the answer that I was looking for...But thanks for answering me back
When I start my script, there is an Error:
"Traceback (most recent call last):
  File "<string>", line 88, in execute
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\management.py", line 12021, in Clip
    raise e
ExecuteError: ERROR 999999: Error executing function.
Failed to execute (Clip)."
So how can I get the extent from my shapefile to make my clip tool work:
arcpy.Clip_management(RasterWorkspace + "\\" + RasterFile, "#", RasterWorkspace + "\\" + OutRasterFile, inputWorkspace + "\\" + ShapeFileName + ".shp", "0", "ClippingGeometry")
CARMETSandrine
Hi Sol,
Yes I've already done that. But the problem is that I want to generalize my script, so that the user of my tool will be able to choose is own shapefile (for extent to the clip tool) and his raster file. But I can't find the properly form to insert my parameters in my tool.
Can you have a look to my script in attachment above, to see if you have any ideas ?
Thanks for helping.
CARMETSandrine
Thank you very much for the advice Sol,
I'm going to see if they can help me in the python forum.
Sandrine
JohannesBierer
In addition to the export out of a model you could print the variables you put in the clip tool to see if there's something wrong:
arcpy.AddMessage(RasterWorkspace + "\\" + RasterFile) ......
CARMETSandrine
The messages didn't show me something wrong.
It seems that the problem come from the shapefile (inputWorkspace + "\\" + ShapeFileName + ".shp")  that I used as an extent for the Clip tool.
Maybe I should use an other function to obtain the extent values from the shapefile, and then put it directly in the clip tool. But I don't know how to do that... I'm going to continue my research.
JohannesBierer
As I can see it's all OK, so I don't know what could be wrong.
It's quite sophisticated what you are doing. Twice the use of parameters[0].valueAsText? One time .valueastext = not correct?
I would try to put the shape in the clip syntax hard coded, to see if it works?
CARMETSandrine
I think I went to far with my script by trying things. I'm going to simplify it as possible.
For the clip, I'll try what you say to see if it works !
Thankss Johannes!
AdamFeidt
These links should help:
Create the custom script tool and define the input parameters via the Add Script Tool Wizard.
http://resources.arcgis.com/en/help/main/10.1/index.html#/Adding_a_script_tool/00150000001r000000/
Access the input parameters and plug them into your Clip_management code:
http://resources.arcgis.com/en/help/main/10.1/index.html#/Accessing_parameters_in_a_script_tool/0015...
