Missing Attributes when creating column chart in arcgis online
1457
08-06-2014 08:57 AM
BrittaneyRoss
Hi can someone shed some light on why only some of my attributes show up as options for creating an infographic chart? all of my attribute fields are numeric so I'm not sure why some are missing.
Thanks!
Tags (1)
MikeMinami
Esri Notable Contributor
What is the source of the layer? Can you share your map publicly? It's possible that a field you believe to be numeric is not. For example, I've seen cases where someone imports a CSV where a numeric field contains a string, and thus the field is defined as a string field when a hosted feature layer is created from it.
Mike
BrittaneyRoss
Thanks Mike,
One of my fields did contain a string I was able to fix the issue
