Require Undefined on server
6656
08-05-2014 03:33 PM
asinha_ppc
I have a simple site that works fine locally, but when I host it on our IIS server, I get "Uncaught ReferenceError: require is not defined".
I have attached the source code. I am a JS newbie and believe this has something to do with the Dojo toolkit. Any hint will be appreciated!
Thanks!
OwenEarley
Your page does not seem to be loading the ESRI JS API:
// Reference the ESRI JS API (add the next line before creating a map)
<script src="http://js.arcgis.com/3.9/"></script>
<script>
    var map;
    require([
      "esri/InfoTemplate",
      "esri/map",
      "esri/layers/FeatureLayer",
      "esri/symbols/SimpleFillSymbol",
The javascript loaded with this script contains the Dojo toolkit code as well.
Not sure how this works locally without this script reference.
Hope this helps,
Owen
Spatial XP
OwenEarley
<script>
    var map;
    require([
      "esri/map",
Hope this helps,
Owen
Spatial XP
asinha_ppc
That did it! Thanks!!
