Reverse GeoCode
5819
10
08-04-2014 06:36 AM
jaykapalczynski
Honored Contributor
Any examples out there of allowing the user to type in a lat long and creating a point at that location and/or zooming to it,,,,
Much like the below but with XY not address
Geocode an address | ArcGIS API for JavaScript
TimWitt2
I built on the example I gave you, check it out:
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Find Address</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
      #map {
        padding: 0;
        border: solid 2px #666;
        margin: 0 5px 5px 5px;
      #header {
        color: #666;
        font-family: sans-serif;
        font-size: 1.1em;
        height: auto;
        margin: 5px;
        overflow: hidden;
        padding: 10px 0 10px 20px;
        text-align:left;
      .roundedCorners {
        -webkit-border-radius: 5px;
        -moz-border-radius: 5px;
        border-radius: 5px;
    </style>
    <script src="http://js.arcgis.com/3.10/"></script>
    <script>
      var map;
      require([
        "esri/map", "esri/tasks/locator", "esri/graphic",
        "esri/geometry/webMercatorUtils",
        "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol",
        "esri/InfoTemplate", "esri/Color", "esri/geometry/Point", "dojo/on",
        "dojo/number", "dojo/parser", "dojo/dom", "dijit/registry", "dijit/form/TextBox", "dijit/form/Button",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
        Map, Locator, Graphic,
        webMercatorUtils,
        SimpleMarkerSymbol, SimpleLineSymbol,
        InfoTemplate, Color, Point, on,
        number, parser, dom, registry, TextBox
        parser.parse();
        map = new Map("map", {
          basemap: "streets",
          center: [-95.273, 38.95],
          zoom: 14
        var symbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_CIRCLE,
          15,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_SOLID,
            new Color([0, 0, 255, 0.5]),
            8
          new Color([0, 0, 255])
        var locator = new Locator("http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer");
        var infoTemplate = new InfoTemplate("Location", "Address: ${Address}");
        locator.on("location-to-address-complete", function(evt) {
          if (evt.address.address) {
            var address = evt.address.address;
            var location = webMercatorUtils.geographicToWebMercator(evt.address.location);
            //this service returns geocoding results in geographic - convert to web mercator to display on map
            // var location = webMercatorUtils.geographicToWebMercator(evt.location);
            var graphic = new Graphic(location, symbol, address, infoTemplate);
            map.graphics.add(graphic);
            map.infoWindow.setTitle(graphic.getTitle());
            map.infoWindow.setContent(graphic.getContent());
            //display the info window with the address information
            var screenPnt = map.toScreen(location);
            map.infoWindow.resize(200,100);
            map.infoWindow.show(screenPnt, map.getInfoWindowAnchor(screenPnt));
        map.on("click", function(evt) {
          map.graphics.clear();
          locator.locationToAddress(webMercatorUtils.webMercatorToGeographic(evt.mapPoint), 100);
        var LongTextBox = new TextBox({
            placeHolder: "Longitude",
            value:"-95.273",
            intermediateChanges:true
        },"LongTextBoxDiv");
                var LatTextBox = new TextBox({
            placeHolder: "Latitude",
            value:"38.95",
        },"LatTextBoxDiv");
        on(registry.byId("latlong"), "click", getaddress);
        function getaddress(){
          var Lat = LatTextBox.get("value");
          var Long = LongTextBox.get("value");
          var LatLongLocation = new Point([Long,Lat]);
          locator.locationToAddress(LatLongLocation , 100);
    </script>
  </head>
  <body class="claro">
    <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'headline', gutters:false"
         style="width:100%; height:100%;">
      <div id="header" class="roundedCorners"
           data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'top'">
        Long: <input id="LongTextBoxDiv" />
        Lat: <input id="LatTextBoxDiv" />
        <button id="latlong" data-dojo-type="dijit.form.Button" type="button" data-dojo-attach-point="button">Get Address</button>
      </div>
      <div id="map" class="roundedCorners"
           data-dojo-props="region:'center'">
      </div>
    </div>
  </body>
</html>
Hope this answers your question!
Tim
TimWitt2
Jay,
you could use this Reverse geocode | ArcGIS API for JavaScript , but instead of a "map on click event" you could create a box, where a user can put in the lat/long, then create a point from that information and use the point as your "evt.mapPoint".
Tim
TimWitt2
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
      #map {
        padding: 0;
      #header {
        color: #666;
        font-size: 1.1em;
        height: auto;
        margin: 5px;
        overflow: hidden;
        text-align:left;
      .roundedCorners {
        border-radius: 5px;
    </style>
    <script>
      var map;
      require([
      ], function(
        webMercatorUtils,
        parser.parse();
          basemap: "streets",
          zoom: 14
          15,
            8
            value:"-95.273",
            value:"38.95",
        },"LatTextBoxDiv");
    </script>
  </head>
      </div>
      </div>
    </div>
  </body>
</html>
Tim
jaykapalczynski
Honored Contributor
Worked great Tim....thanks...
And thats Jeff....will be revisiting this once I figure out what their preference is.....so if the do degrees minutes seconds...I test for this?  Then grab the values from the textboxes and convert them pass to the locator?
TimWitt2
You convert it from deg/min/sec and once you have your Lat/Long feed them into line 122, here:
JeffJacobson
You may need this too, depending on if your users want to enter degrees-minutes-seconds:
Parse Degrees Minutes Seconds (DMS) into Decimal Degrees
jaykapalczynski
Honored Contributor
How would I zoom to it?
Would like to zoom to the Graphic being created below
            var graphic = new Graphic(location, ReverseGeocodesymbol, address, infoTemplateRG);
            app.map.graphics.add(graphic);
            app.map.infoWindow.setTitle(graphic.getTitle());
            app.map.infoWindow.setContent(graphic.getContent());
            var screenPnt = app.map.toScreen(location);
            app.map.infoWindow.resize(200,100);
            app.map.infoWindow.show(screenPnt, app.map.getInfoWindowAnchor(screenPnt));
          var stateExtent = location [0].geometry.getExtent().expand(5.0);
            map
.setExtent(stateExtent);
TimWitt2
Instead of what you have, add the following:
var graphicExtent = graphic._extent.getExtent();
map.setExtent(graphicExtent);
Hope this helps!
Tim
jaykapalczynski
Honored Contributor
I do this and nothing happens..
Also tried getting rid of the _ in your example and still no zooming
Trying this way
var graphicExtent = graphic.extent.getExtent();
Error
TypeError {stack: (...), message: "Cannot read property 'getExtent' of undefined"
           app.map.setExtent(graphicExtent);
jaykapalczynski
Honored Contributor
THink I got it....I was not moving my map...I moved my map and ran it and it centered on the graphic being created.....my next and last question ....how do I zoom to it...can I do this
var graphicExtent = graphic1._extent.getExtent().zoomin;
Something similar to the map  :  zoom: 7,
Tried this and no go
  app.map.centerAndZoom(graphicExtent,7);
