JavaScript Color Palette in RGB rather than Hexidecimal?
4973
6
08-04-2014 06:59 AM
IanPeebles
I am currently using the JavaScript color pallete from dijit.ColorPalette.  Is there a color pallete that contains RGB values?  The reason I am asking is that I want to make polygon features transparent.
Tags (1)
TimWitt2
Ian,
you could set the opacity property when you create your graphic or later on use the setOpacity method of your graphic layer to do that.
Tim
TimWitt2
You could use the color picker instead? dojox.widget.ColorPicker — The Dojo Toolkit - Reference Guide
RiyasDeen
Still with RGB alone you can't create transparency, you'll need to alpha as well.
IanPeebles
Thanks for the feedback so far.  What would be the best solution to allow the user to choose from a variety of colors and have the transparency set at 50 percent?  So far, I have the color palette working, yet the graphics are a solid fill.  I am looking for something simple.
TimWitt2
Ian,
Tim
IanPeebles
Thanks for all of the responses.  I set a transparency for all graphics, using a opacity of .25.  Here is how it turned out:
TimWitt2
I'm glad it worked!
