progress while loading feature layer.
2711
7
07-29-2014 11:32 AM
jaykapalczynski
Honored Contributor
Is there a way to alert the user while a layer is being drawn o the screen...
I have one that is rather large and it take a second or two...I have it scale dependent so it only draws when zoomed far in but is still a bit large...I want them to know for sure that its drawn completely.
I have an image that spins but just dont know where to put the code to start and stop (show and hide) this image.
var flArchitecture = new FeatureLayer("https://server/arcgis/rest/services/Test/Resources/MapServer/1", {
         mode: FeatureLayer.MODE_ONDEMAND,
         infoTemplate: templateHR,
         outFields: ['*']
app.map.addLayer(flArchitecture);
TracySchloss
Honored Contributor
I have mine placed on the map events.  This works pretty well since then I don't have to track which type of layer is currently loading.   I have a loading image within my mapDiv
<img id="loadingImg" src="images/loading.gif" alt="Loading image" style="position:absolute; left:350px; top:250px; z-index:100;" />
var loading = dom.byId("loadingImg");
map.on('update-start', showLoading);
map.on('update-end', hideLoading);
   function showLoading(){
    domUtils.show(loading);
    map.disableMapNavigation();
    map.hideZoomSlider();
  function hideLoading(error){
    domUtils.hide(loading);
    map.enableMapNavigation();
    map.showZoomSlider();
TimWitt2
You could fire an event that shows your image on update-start and then remove the image on update-end.
KevinDeege
Hi Jay, this might work for you:
JS API 3.2 - When do layers render?
The map and the featurelayer both have this property (update-end)
featurelayer-amd | API Reference | ArcGIS API for JavaScript
TracySchloss
Honored Contributor
jaykapalczynski
Honored Contributor
Thank all....
I do the below and it breaks....I comment out the 2 "app.map.on" and the image shows up but there is no control to stop it...
Is there a Require that I am missing?
UPDATE:
jaykapalczynski
Honored Contributor
Tracy..I think I see it...your example
map.on('update-end' ) , hideLoading);
you had an extra ) after update-end
Working now...THANK YOU ALL FOR YOUR THOUGHTS AND HELP
TracySchloss
Honored Contributor
Glad you figured it out. I was having some very weird behavior with my copy/paste, so I was manually trying to type out the parts that weren't right. I fixed my answer so other people will have the right syntax.
jaykapalczynski
Honored Contributor
Wanted to give credit to all of you that chimed in on this post.....I thank you all very much....
