Geocoder - how to go to value at startup?
1379
07-28-2014 02:29 PM
LauraLance
I am specifying a value for input textbox of the geocoder. It is a field (geoPlace) that is calculated. It fills in the textbox just fine. I would like for it to then automatically zoom to that place at startup. Is there a way to do this? It seems like I should use geocoder.find() but I haven't been successful.
    geocoder = new Geocoder({
        map: map,
        value: geoPlace
    }, "search");
    geocoder.startup();
Tags (1)
OwenEarley
Hi Laura,
Check out the Geocode an address | ArcGIS API for JavaScript‌ sample. This sample geocodes an address then zooms to the location.
You should be able to insert your geoPlace variable into the locate function - something like:
function locate() {
          map.graphics.clear();
          var address = {
            "SingleLine": geoPlace
          locator.outSpatialReference = map.spatialReference;
          var options = {
            address: address,
            outFields: ["Loc_name"]
          locator.addressToLocations(options);
Hope this helps,
Owen
www.spatialxp.com.au
OwenEarley
Hi Laura,
function locate() {
          var address = {
          var options = {
            address: address,
Hope this helps,
Owen
LauraLance
Thank you! This is exactly what I needed.
