Create a WebMap by ID sample using JS not running
1425
07-23-2014 01:49 AM
HumzaAkhtar
I started learning ArcGIS API for JS today and I successfully displayed a simple basemap using the sample code provided in the first tutorial. However when I downloaded the 'Create Webmap' sample as a zip and tried to run it, it doesnot display any webmap except for the headers. I have tried changing web map IDs and although the sample runs in the sandbox, it displays blank screen when i download the html file and try to run it from my browser.  Did anyone else experienced this issue? what can be the problem here. I have not modified the code in any way except for testing with different webmap IDs.
NicholasHaney
Looks like it may be a problem with ArcGIS online. The sample is not working: Create web map from id‌. Change the web map ID to a different web map and see if that fixes it.
