How to disable click on featureLayer ?
1987
8
07-22-2014 12:38 AM
Enguerranddes_Vaux
i would like to do it in order to edit graphics and not have the infoWindow pops up when i edit a graphic. thx for any help
I have try .disableMouseEvents(); but it's not working
TimWitt2
To solve that, I use right click to edit graphics. Would that be an option?
Advanced Draw - JSFiddle
Enguerranddes_Vaux
it's a good option but i have to use the left click
TimWitt2
Can you post your code?
Enguerranddes_Vaux
My listener :
this.graphicLayerObj.on("click",lang.hitch(this,function(evt){
                if(dom.byId("drawingContainer").innerHTML=="" && domStyle.get(widgetTool.drawingToolsNode,"backgroundColor")=="rgba(71, 71, 71, 0.4)"){
                    this.activateToolbar(evt.graphic);
activateToolbar: function(graphic) {
            var tool = 0;
            tool = tool | Edit.MOVE;
            tool = tool | Edit.EDIT_VERTICES;
            tool = tool | Edit.SCALE;
            tool = tool | Edit.ROTATE;
            // enable text editing if a graphic uses a text symbol
            if (graphic.symbol.declaredClass === "esri.symbol.TextSymbol") {
                tool = tool | Edit.EDIT_TEXT;
            //specify toolbar options
            var options = {
                allowAddVertices : true,
                allowDeleteVertices : true,
                uniformScaling : true
            editToolbar.activate(tool, graphic, options);
TimWitt2
Instead of turning off the click on featureLayer, you could disable the pop-ups while you edit, as outlined here?
Enguerranddes_Vaux
I have 5 featureLayers how to do it for each ?
TimWitt2
How do you create your pop-ups?
Enguerranddes_Vaux
i'm not creating them i get the map with the arcgisUtils.createMap(); method
