2 buttons 2 different functions
3587
7
07-21-2014 03:05 PM
jaykapalczynski
Honored Contributor
I have been bashing my head against the wall for over a week now....I cant get this to work....I trimmed it down the best I could in the link below.
If oyouhit the first button on the right (identify) and click somewhere in Virginia it runs the code and returns results in a container on the right.  Promting a few alerts along the way,
The click the second button (Buffer).  When you click the map the prompts from the Identify still appear as well as the buffer alerts.  The buffer code runs fine, BUT the identify is also running forcing unneeded processing.
I have tried everything I could think of and Cannot get the identify to STOP running after one clicks the Buffer Button.
Can someone PLEASE put their eyes on this and maybe help me determine why I cannot shut off the Identify Code.
WEBSITE can be found here:  Application
KenBuja
MVP Esteemed Contributor
action3 = on.pausable(app.map, "click", function(evt) {
       executeIdentifyTask(map);  // Call Identify function
Your executeIdentifyTask is expecting an event, not a map.
function executeIdentifyTask (event) {
    identifyParams.geometry = event.mapPoint;
KenBuja
You didn't set action3 to be a pausable event like you did for action2
function Identify() {
 domUtils.toggle(dom.byId("divLayerContainer"));
 if (action2 != undefined) {
  action2.pause();
 //action2.remove();
 alert("Action2 != undefined");
  if (action3 == undefined) {
 alert("Action3 A");
 action3 = app.map.on("click", executeIdentifyTask);
  //featureLayer.setInfoTemplate(template);
  else {
  action3.resume();
 alert("Action3 B");
You should use a tool like Firebug. It shows that error
williamcarr
Ken,
     Just wondering, could you set a pause to "toggle" between an attribute inspector and a popup?
jaykapalczynski
Honored Contributor
First off THANKS Ken
I change to this and it just spins....no results returned....
I still get the 2 alerts from the two identify functions but no results!!!
        alert("in executeIdentifyTask");
function initializeSidebar(map){
       alert("in initialize sidebar");
CHANGED THIS
//action3 = app.map.on("click", executeIdentifyTask);
TO THIS
jaykapalczynski
Honored Contributor
I am reworked to do it this way and the two buttons are seemly to be playing nicely....where as, when I go between them I am not being prompted by alerts from the other Functions.
BUT For some reason I am not getting any return data to the window....very puzzled..
            action2.pause();
     alert("Action3 A");
  else {
      action3.resume();
     alert("Action3 B");
function Buffer() {
  app.map.setMapCursor("crosshair");
  dojo.byId("divLayerContainer").style.display = "none";
  alert("In Initial Buffer");
  if (action3 != undefined) {
             action3.pause();
      alert("Action3 != undefined");
  if (action2 == undefined) {
        alert("Action2 A");
        action2 = on.pausable(app.map, "click", function(evt) {
               var params = new BufferParameters();
                        params.geometries  = [ evt.mapPoint ];
                       params.distances = [ 25 ];
                       params.outSpatialReference = app.map.spatialReference;
                        params.unit = GeometryService.UNIT_STATUTE_MILE;
        BufferTool(map, params);  // Call BufferTool function and pass the Buffer Parameters
   else {
        alert("Action2 B");
        action2.resume();
jaykapalczynski
Honored Contributor
Not sure what this is telling me from the Console....something about missing geometry when I made the changes.
Error {code: 400, message: "Missing 'geometry' for identify operation.", details: Array[0], log: undefined, httpCode: 400…}
_ssl: undefined
code: 400
details: Array[0]
httpCode: 400
log: undefined
stack: "Error↵    at Error (native)↵    at Object.e.load (https://js.arcgis.com/3.10/init.js:619:426)↵    at https://js.arcgis.com/3.10/init.js:187:69↵    at c (https://js.arcgis.com/3.10/init.js:74:221)↵    at d (https://js.arcgis.com/3.10/init.js:74:10)↵    at resolve.callback (https://js.arcgis.com/3.10/init.js:75:350)↵    at c (https://js.arcgis.com/3.10/init.js:74:436)↵    at d (https://js.arcgis.com/3.10/init.js:74:10)↵    at resolve.callback (https://js.arcgis.com/3.10/init.js:75:350)↵    at https://js.arcgis.com/3.10/init.js:191:300"
__proto__: d
init.js:188
TypeError {stack: "TypeError: Cannot read property 'length' of null↵ …errback (https://js.arcgis.com/3.10/init.js:76:1)", message: "Cannot read property 'length' of null"}
    at null.<anonymous> (http://localhost/dgifmapping/js/AppLayout_Warbler12.js:520:55)
    at h.(anonymous function).g [as onSetFeatures] (https://js.arcgis.com/3.10/init.js:239:390)
    at e._updateFeatures (https://js.arcgis.com/3.10/init.js:1207:314)
    at https://js.arcgis.com/3.10/init.js:173:204
    at reject.errback (https://js.arcgis.com/3.10/init.js:76:1)
    at c (https://js.arcgis.com/3.10/init.js:74:493)
    at reject.errback (https://js.arcgis.com/3.10/init.js:76:1)" init.js:205
Error {stack: "Error↵    at Error (native)↵    at Object.e.load (…    at https://js.arcgis.com/3.10/init.js:191:300", code: 400, message: "Missing 'geometry' for identify operation.", details: Array[0], log: undefined…}
"Error
    at Error (native)
KenBuja
jaykapalczynski
Honored Contributor
Think this is working....I owe you a cold one Ken..I cant thank you enough for your eyes and help....learning every day here....MUCH Appreciated....
  executeIdentifyTask(evt);  // Call Identify function
UPDATE:  VERIFY its working......CHEERS Thanks a million
