Problem centering to a polygon. Javascript api
2831
07-21-2014 11:40 AM
alexlambson
So I am pulling parcels, running a query, and trying to center the map to the parcels from the query.
I am getting this error:
Map: Geometry (wkid: 26912) cannot be converted to spatial reference of the map (wkid: 102100)
The coordinates I get from the query are ridiculous, an example is [4109465.94230973, 270652.7635476563]. They display fine when I enable the layer, though. It is only when I do a query that things get weird.
and this is all of my code dealing with the parcels
$(document).on('click', '#parcel_submit', function(){          parcelId = $('#parcel_input').val(); //get the parcel to search for from the text box          queryTask = new esri.tasks.QueryTask("https://mapserv.utah.gov/arcgis/rest/services/Parcels/MapServer/27");     //initialize query     query = new esri.tasks.Query();     query.returnGeometry = true;     query.outFields = ["OBJECTID", "PARCEL_ID"];     query.where = "PARCEL_ID = '" + parcelId + "';"; //only look for the desired parcel     queryTask.execute(query,showResults);      }); function showResults(featureSet){     var features = featureSet.features; //all of the parcels matching the search. There should only be one     var parcel = features[0]; //get the first parcel     var geometry = parcel.geometry.getCentroid(); //get the center of the parcel     var point = esri.geometry.Point(geometry.y, geometry.x) //create a point     map.centerAndZoom(geometry, 16); //it is centering at some crazy coordinates in the hundreds of thousands.      console.log(features, parcel, geometry, point); };
Thanks in advance.
Bit of honesty, I hardly know the basics since this project was assigned out of nowhere 😕 I apologize if this question is dumb
JakeSkinner
Esri Esteemed Contributor
Hi Alex,
Try specifying the outSpatialReference property for the Query class to be the same as the map's spatial reference.  Ex:
query.outSpatialReference = map.spatialReference;
JakeSkinner
Hi Alex,
alexlambson
Thank you!
Thanks to people like you, I am slowly learning this api.
