Brower buggs with maps
1027
07-17-2014 02:32 AM
maximcouton
I am using the ArcGis Api for JavaScript ,
I have a map and two layers:
   1 : esri/layers/KMLLayer
  2 :  esri/layers/ArcGISTiledMapServiceLayer
I am trying to reorder the two layer on a button click : I am procedeeding like this :
  - remove the two layer
  - reorder my layers inside an array
  - at this point the map contains  no layer and the array contains the exact order of the layers
  - adding two layers to the map
Unfortunately I am getting this error in chrome :
Error : Inspected target has crashed . Once it reloads we will attach to it automatically.
I tryed the same with 2  esri/layers/ArcGISTiledMapServiceLayer  every thing works fine.
Any idea of what is causing me this issue ?
maximcouton
apparently the error is generated by this script :    js.arcgis.com/3.9/js/esri/geometry/Extent.js:30
