Why won't ArcGIS API for JavaScript Sandbox page display my web map?
3330
07-15-2014 06:16 PM
by Anonymous User
Not applicable
Going through the Tutorials | ArcGIS API for JavaScript and tried to display my map using the template code in the sandbox site (ArcGIS API for JavaScript Sandbox‌), but it won't take. I made sure my web map was public and I got someone else to test it as well.
AlexanderNohe1
Honored Contributor
Hi Ben Gardner‌,
I was able to reproduce the same behavior using your webmap.  I saved a copy of your webmap and was able to reproduce there as well.
When watching the network traffic, I noticed that it was running into some trouble reading a directory on your ArcGIS Server.
I hope this helps!
AlexanderNohe1
Honored Contributor
Hello
What is your webmap id so we can test on our end.
Thanks!
by Anonymous User
Not applicable
map ID: acae825ec19046f1b1923d24e435f30a
Here's the code:
<!DOCTYPE html>
  <html>
  <head>
  <title>Create a Web Map</title>
  <meta http-equiv="X-UA-Compatible" content="IE=edge">
  <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
  <style>
    html,body,#mapDiv,.map.container{
      padding:0;
      margin:0;
      height:100%;
  </style>
  <script>var dojoConfig = { parseOnLoad:true };</script>
  <script src="http://js.arcgis.com/3.10compact/"></script>
  <script>
    var map;
    require([
        "esri/map",
        "esri/arcgis/utils",
        "dojo/domReady!"
        ], function(Map, arcgisUtils){
        arcgisUtils.createMap("acae825ec19046f1b1923d24e435f30a", "mapDiv").then(function (response) {
            map = response.map;
  </script>
  </head>
  <body>
    <div id="mapDiv"></div>
  </body>
  </html>
AlexanderNohe1
Honored Contributor
Hi Ben Gardner‌,
I hope this helps!
by Anonymous User
Not applicable
Hmm. I wonder if it's because I imported a base map from our internal web server when I initially put the map together.
Thanks Alexander. Gives me a little more insight into the ArcGIS API.
