ESRI JavaScript API 3.8 Locator: SyntaxError {log: undefined, stack: (…), message: “Unexpected token <”}
5516
07-10-2014 09:51 AM
BrandonColeman
I am having issues trying to set up a geocoder/locator on my server and also trying to query my geometry service when trying to project some lat/long coordinated. I keep getting an error SyntaxError {log: undefined, stack: (...), message: "Unexpected token <"}, but I can't seem to figure out why. I tried exploring the error message, but I don't get much good information out of it.
I have tried using ESRI's geocoder widget then created my own set up using the locator service. I have checked my address string, and I believe it should be passing correctly over to the server.
If I am understanding the error message right, it is saying there is a token "<" somewhere that shouldn't be there, but I cannot find it.
Other info... I am running version 9.3.1 for my server, using the JavaScript API 3.8 that ESRI hosts, and created an address locator on my server using street centerlines for the area I am mapping.
Has anyone run into this issue before or have suggestions for me? Right now, I am just trying to center the map on the location. Once I get that done, I can worry about all the other stuff.
My code for the locator is below.  The site I am working on is at: Louisville Urban Tree Canopy Analysis‌.
locator = new Locator(singleFieldGeocodeURL);
//add handler for completion
locator.on("address-to-locations-complete", showResults);
//trying to find the error
locator.on("error", function (error) {
  errorObject = error;
  console.log("error" + error);
//add handler for button click
on(dom.byId('locate'), 'click', function () {
  console.log(dom.byId('address').value);
  map.graphics.clear();
  var address = {
  "SingleLine": dom.byId('address').value
  locator.outSpatialReference = map.spatialReference;
  var options = {
  address: { street: address },
  outFields: ["Loc_name"]
  locator.addressToLocations(options);
function showResults(evt) {
  console.log("in show results");
  var candidate;
  var symbol = new SimpleMarkerSymbol();
  symbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE);
  symbol.setColor(new Color([153, 0, 51, 0.75]));
  var geom;
  arrayUtils.event(evt.addresses, function (candidate) {
  console.log(candidate.score);
  if (candidate.score > 80) {
  console.log(candidate.location);
  var attributes = {
  address: candidate.address,
  score: candidate.score,
  locatorName: candidate.attributes.Loc_name
  geom = candidate.location;
  var graphic = new Graphic(geom, symbol, attributes, null);
  map.graphics.add(graphic);
  return false;
  if (geom !== undefined) {
  map.centerAndZoom(geom, 12);
IanGrasshoff
That's the type of error you get when trying to access a secure service without logging in/providing a token via your code.  I would start by checking the security on your ArcGIS server rest service/folder.  If you have security switched on, then you will need to provide a token (you should use a proxy page).  If you don't need security just switch it off and try again.
IanGrasshoff
Also, it would help if you posted a code snippet so we can see how you setup/use the Geocoder widget.  Sometimes the token errors aren't related to security but have to do with some invalid parameter.
BrandonColeman
Here is the code I was using for the widget...  I added in a div id='search' to try this on.  I am not sure about the 3rd parameter of the myGeocoders list though.  The first time I tried it, I wasn't using a 3rd parameter.  I just tried it using the SingleField geocoder, and I got the same message.
var myGeocoders = [{ url: singleFieldGeocodeURL, name: "SingleField", singleLineFieldName: "ROADNAME" }, { url: alphaNumericGeocodeURL, name: "AlphaNumeric" }];
        geocoder = new Geocoder({
        map: map,
        autoComplete: true,
        arcgisGeocoder: false,
        geocoders: myGeocoders
         }, "search");
geocoder.startup();
Also, for sharing the the ArcGIS Server/Rest folder... I didn't set up the server so I am not sure if it is set properly.  For the rest folder, do I have to grant the SOC and SOM user accounts read/write access to it?
Also, I have tried using the geometry service I set up, and I got the same error message.  For that, I was trying to use HTML5's geolocation to position the map to the person's approximate location.  I was trying to use the geometry service to reproject the lat/long coords into my map's projection.  That code is:
on(map, "load", function () {
        if (navigator.geolocation) {
            navigator.geolocation.getCurrentPosition(ZoomToPosition);
    function ZoomToPosition(position) {
        symbol.setStyle(SimpleMarkerSymbol.STYLE_CIRCLE);
        var input = new Point(position.coords.latitude, position.coords.longitude, new SpatialReference({wkid: 4326}));
        var PrjParams = new ProjectParameters();
        PrjParams.geometries = [input];
        PrjParams.outSR = new SpatialReference({ wkid: 2246 });
        geometryService.project(PrjParams, function (outputPoint) {
        var graph = new Graphic(outputPoint, symbol);
        map.graphics.add(graph);
        map.centerAndZoom(graph, 12);
Thanks again for any advice!
BrandonColeman
I found out from someone on GIS Stack Exchange that my issue was something as simple as a wrong URL.  My URL wasn't point at the rest directory in my code.
That error is gone now.  Thanks to anyone who was trying to help me out on this!
