Documentation about ESRI XSL-Format
3462
07-11-2014 04:43 AM
NicoleZöllner
Has anbody an idea where I can find some documentations to write my one *.xsl for changing the style of WMS rsponse?
is XSL a special ESRI-Format or is it a general scripting language?
I can not find documentations except some small pages in the Ersi Resouce Center
I'll be happy about a promt answer.
Kind regards,
Nicole Zöllner
alta4 AG, Trier
http://www.alta4.com
RobertMaddox
I'm not sure about this particular usage, but XSL is the XML Stylesheet Language, which is written in XML and used to process / transform XML. See more about it here: XSL Languages
Now how ESRI is using XSL in this particular case, I do not know. Is this "WMS response" you mentioned using XML? If so, then you might be able to just use XSL (XSLT or XSL-FO) to manipulate the XML response in whatever way you wish. Otherwise, it might be something else entirely.
Hope that helps some.
DonOpgenorth
I've moved your post into the  Enterprise GIS space.  You will get a much better answer here as the GeoNet Help is intended for community help and feedback. I have also added in a few additional tags. You can see more
on the community structure, and what topics are under each space from the following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Don
