query.fields
2962
6
07-10-2014 06:18 AM
AlexandrIvanov
Hello.
I'm doing an application based on a sample - ArcGIS API for JavaScript Sandbox
Only in my case initially loaded all the fields:
//build query filter
query = new esri.tasks.Query();
query.outSpatialReference = {"wkid": 102100};
query.returnGeometry = true;
query.outFields = ["*"];
//create the infoTemplate to be used in the infoWindow.
infoTemplate = new esri.InfoTemplate("${FIELD_NAME}", "${*}");
Next I need to be able to choose the displayed fields, how can I get a list of all the fields layer
Thanks in advance and sorry for my english
KenBuja
MVP Esteemed Contributor
You can use this to list all the fields
infoTemplate = new esri.InfoTemplate("Attributes", "${*}");
AlexandrIvanov
I do so, but how do I get such a third element of this list?
KenBuja
I'm not sure what you mean by a third element. Can you explain that in more detail?
AlexandrIvanov
I load into the application map
load all the attributes:
now I want to get the first, third and fifth attribute from the list what they do not know.
For example: with the line "infoTemplate = new esri.InfoTemplate("Attributes", "${*}");  I get a list of attributes:
number
name
surname
rent
date1
date2
data3
when after press a button I should get a window with the inscription
number, surname, date1
something like -
number
name
surname
rent
date1
date2
data3
something like:
alert(infoTemplate.content[1] + "; "+ infoTemplate.content[3]+", "+infoTemplate.content[5])
LuciHawkins
Are you saying that you will not know the names of the fields until after the first query is run?  Then you want to select the fields from the first query to show in the infowindow?
or
If you want an infotemplate with just your 3 fields - number, surname, date1  - use the following:
var infoTemplate = new InfoTemplate("Attributes", "<tr>number:<td>${number}</tr></td><br><tr>surname:<td>${surname}</tr></td><br><tr>date1:<td>${date1}</tr></td>");
Luci
AlexandrIvanov
I made the ability to upload any layer. Therefore I am do not know what attributes of the table will be loaded. For further action I need to know the names of these attributes. The first attribute, third and fifth - is for illustrative purposes only
