How to handle query results from multiple fields
2381
6
07-09-2014 03:01 PM
MatthewBaker2
Hi all,
With thanks to John Gravois, I've been able to pass geometry from the result of a geocoder, along with a field name, to a spatial intersection query to run against a school boundary layer.
What I'd like to do is pull the school boundary number from the corresponding field the user chooses - that is - the user chooses Grade 6 from the drop down, which means I want the value from the SCHOOL_6 field in the boundary layer I'm querying.
So I'm wondering how I should do this:
1) Do I use the SCHOOL_6 value in the outfields query parameter and pull that value, which yields this result:
additionally - how do I pull that value 416 if there is only ever 1 feature returned, but the field name could always change based on the drop-down?
or ...
2) Pull all the fields from the query layer, and select the attribute from the field that matches the value of the drop-down (ie. SCHOOL_6), and sift through the results that way. Here's what the results look like from pulling all the fields:
The purpose of pulling this boundary number is that it will go into the last query, which will pull all the schools belonging to that boundary number.
UPDATE: I have added the code I am working on. cc Jake Skinner
Any thoughts appreciated.
Message was edited by: Matthew Baker
JohnGravois
you can retrieve values from a known field a couple different ways...
attributes.FIELDNAME
attributes["FIELDNAME"]
the second syntax would be better for you if you want to substitute a variable.
JakeSkinner
Esri Esteemed Contributor
Hi Matthew,
It may be helpful to post the code you are working with.
MatthewBaker2
Jake Skinner‌, added the code I'm working with.
JakeSkinner
Try the following:
qt.execute(queryBounds, function(results) {
    var resultBound;
    resultBound = results.features[0].attributes;
    console.log(resultBound);
JohnGravois
MatthewBaker2
JGravois-esristaff‌ perfecto! That works great and will let me do exactly what I need - substitute the variable from the drop-down to the result specific to the corresponding field... great stuff!!! Many thanks to both of you! cc jskinner-esristaff
JohnGravois
anytime amigo.
