Add KML stream to map
1331
07-09-2014 02:20 AM
maximcouton
I want to add a Kml layer to a map. The data is string under kml format. I fought that the api  allows to add a kml layer by giving it a URL, but I can't found un example adding a kml layer by reading it's content from a stream string.
Use case :
  I have a kml file, I want to parse its content and add it to the map.
Maxim,
JoeFlannery
Honored Contributor
Have you tried the KML to Layer (Conversion) tool?
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
maximcouton
    I am using the ArcGis API  for JavaScript. I am Parsing  the kml file and get its content as an xml stream.
    The Api allows to add a KML layer using an URL but unfortunalety I can't with an XML stream.
    This is kind of a limitation of the ArcGis API,
require(["esri/map", "esri/layers/KMLLayer"],
        function ( Map,KMLLayer ){
           var kmladdress =  kmlUrl; // ONLY THE URL ALLOWED HER , XML/KML STRING IS NOT WORKING
           var kmlLayer = new KMLLayer(kmladdress);
           _map.addLayer(kmlLayer);
   So I  you got any idea of how doing it please notify me,
Maxim
DonOpgenorth
I've moved your post into the  Arcgis API for
Javascript
space. You will get a much better answer here as the GeoNet Help is intended for community
help and feedback. I have also added in a few additional tags. You can see more
on the community structure, and what topics are under each space from the following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Don
