Find and replace a character within a field in geodatabase
1718
07-08-2014 02:17 AM
PeterVersteeg
Hello I have a geodatabase with many features with tables.
I use a tool that splits a features by attribute
(build by Dan_Patterson,    http://resources.arcgis.com/gallery/file/geoprocessing/details?entryID=37AEB018-1422-2418-A036-CA6D9...).
Same field I use have a comma(,) in it and the tool Dan build cannot work with that.
For now I use the find and replace from the table options to make de "," a "_".
Is there a tool or script that will do the search and replace in my geadatabase for all features?
Thank you and Greetings Peter
DuncanHornby
MVP Notable Contributor
Peter,
I am not aware of a built in tool that can do this.
Can you program in Python?  You could create a cursor that cycles through a workspace then get the attribute table and run some sort of update cursor on the specified field.
Duncan
HåvardMoe
Wouldn't it be possible to just use CalculateField with a small script code block to replace the commas?
Expression: "Recode(!FIELDNAME!)
ExpressionType = "PYTHON_9.3"
Code Block:
def Recode(input):
    output = input.replace(',', '_')
    return output
This could be wrapped in code to iterate feature classes and fields for an entire geodatabase if needed...
PeterVersteeg
Thank you all for the fast reply. I will be on the lookout for your new build Dan. But in the meantime I will try the script and make a model.
DanPatterson_Retired
Special characters will be incorporated in the next build...they were omitted to ensure that the backslash ( \ ) wouldn't be encountered during a Python query.
