ArcGIS Server 10.2.2 error message when registering a database, data store tab
7213
07-02-2014 12:00 PM
JoseSanchez
Hello everyone,
Configuration:
Windows Server 2012R2
Using ArcCatalog 10.2.2 when selecting an ArcGIS Server, under Server properties, it opens a window with a tab called Data Store. In this tab  when I create a new Register Database I get the following error message:
Machine xxxx cannot connect to database because the database client failed to load. Be sure the database software is installed and configure correctly.
I installed Oracle 11 client 32 bits. I am able to see the SDE database with ArcCatalog.
Any ideas of how to fix this issue?
George_Thompson
Esri Notable Contributor
Jose,
Be sure to add the 64-bit client for Oracle also.
This will explain the details. After you update the PATH variable, you will need to restart the ArcGIS Server instance.
Configure a connection to the database in ArcGIS Server:
http://resources.arcgis.com/en/help/main/10.2/index.html#//015400000693000000
Install the Oracle Client:
http://resources.arcgis.com/en/help/main/10.2/index.html#//002n00000038000000
-George
--- George T.
MarkBenishek
I had installed both the 64 and 32-bit Oracle Instant Clients, it was the restart of the ArcGIS Server Windows service that corrected my issue.  Thank you George and Joe!
JoseSanchez
Thank you George, it worked following your steps.
George_Thompson
I am glad that took care of the client issue.
Please mark the post as answered. It will help other people who search.
-George
--- George T.
