Geodatabases and ArcGIS Server
4240
02-25-2015 05:20 PM
MarleneSanchez
My goal is to be able to create and share a customized interactive map. Much like the ones you see on local government websites.
Can anyone say if the following is a good strategy to accomplish this?
  • Create a PostgreSQL database, geographically enabled with PostGIS.
    Is it possible to rely entirely on ArcGIS Server to store and call up map layers without the use of database management software?
I don't yet understand the role of ArcGIS Server when enterprise databases are used. I know that ArcMap 10.2 can connect to PostgreSQL and that I may be prompted for an ArcGIS Server authorization file when using the Create/Enable Geodatabase tool in ArcMap or ArcCatalog.
  • Amazon supports hosting ArcGIS Server. What are the alternatives to using that service?
