Arcgis 10.1 layers failed to draw
2102
06-26-2014 05:44 AM
Pierre-LucBoivin
After opening my mxd, I had an a error popup window telling me that "One or more layers failed to draw: The index Was Not Within the valid range".
I had around a 50 error was due to a problem schema table after using the tool "Append".
[ATTACH=CONFIG]34908[/ATTACH]
My problem is that I just have one last error and I don't know which layer it is.
I have almost 35 layers in my mxd with differents display range scale and sometime multiple labeling range by layers. Is there a way that I could know which layer is causing the problem ?
Thanks you for your help
