Problems projecting a point
1630
06-17-2014 12:58 PM
heatherdaw
I am trying to display a point that is in UTM NAD83 Zone 11.  When I try to project the point to Web Mercator, the point's coordinates seem to revert to Null and display just West of Africa instead of in Western Canada where I want it.  I thought I had based my script on various online samples (including this post: http://forums.arcgis.com/threads/36983-geometry-task-project-bug), but clearly something is missing.  Here's part of the script (the entire script has been attached):
  //convert point's coordinates from UTM NAD83 zone11 to Universal Tranverse Meracator:
function getCoordinates() {
   var easting = 422310.0;
          var northing = 5853918.0;
    var newlong = null;
   var newlat = null;
   var newpoint = null;
    var inSR = new esri.SpatialReference({
              wkid: 26911
   var outSR = new esri.SpatialReference({
              wkid: 3857
   var geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
            var inputpoint = new esri.geometry.Point(easting, northing, inSR);
     var PrjParams = new esri.tasks.ProjectParameters();
            PrjParams.geometries = [ inputpoint ];
     PrjParams.outSR = outSR;
     geometryService.project(PrjParams, function(outputpoint) {
     newpoint = outputpoint[0];
          var point = new esri.geometry.Point(newpoint, outSR);
          return point;
Suggestions?
Heather
JonathanUihlein
          return point;
This code exists outside your GeometryService projection callback so newpoint will always equal null.
This is both a scope and timing issue.
In the context of your current application, you would need to figure out a way to return the result of your projection to mapLoaded() based on the deferred response.
Note: I wouldn't do that. It's far easier to restructure your application to be more 'script-like' in its execution.
I would create a function specifically for projecting your point from your mapLoaded() function.
Example below:
<!DOCTYPE html>
<html>
  <head>
    <title>View Site</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css">
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
    </style>
    <script src="http://js.arcgis.com/3.9/"></script>
    <script>
      var map;
      require([
        "esri/map", "esri/graphic", "esri/symbols/SimpleMarkerSymbol",
        "esri/tasks/GeometryService", "esri/tasks/ProjectParameters",
        "esri/SpatialReference", "esri/geometry/Extent", "esri/geometry/Point"
      ], function(
        Map, Graphic, SimpleMarkerSymbol,
        GeometryService, ProjectParameters, SpatialReference, Extent, Point
        map = new Map("map",{
          basemap: "topo",
          extent: new Extent(-13306545,6831419,-13027688,7064868, new SpatialReference({ wkid: 3857})),
          minZoom: 2
        map.on("load", mapLoaded);
        function mapLoaded(){
          map.graphics.clear();
          showPoint();
        function createSymbol(){
          var markerSymbol = new SimpleMarkerSymbol();
          markerSymbol.setColor("blue");
          markerSymbol.setOutline(null);
          return markerSymbol;
        function showPoint() {
          var newlong = null;
          var newlat = null;
          var inSR = new SpatialReference({ wkid: 26911 });
          var outSR = new SpatialReference({ wkid: 3857 });
          var geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
          var inputpoint = new Point(easting, northing, inSR);
          var PrjParams = new ProjectParameters();
            var point = new Point(outputpoint[0], outSR);
            var graphic = new Graphic(point, createSymbol());
            map.graphics.add(graphic);
    </script>
  </head>
  <body class="claro">
    <div id="map"></div>
    <div id="picker1"></div>
  </body>
</html>
JonathanUihlein
          return point;
Example below:
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
    </style>
    <script>
      var map;
      require([
      ], function(
          basemap: "topo",
          minZoom: 2
          showPoint();
          var newlong = null;
          var newlat = null;
    </script>
  </head>
  </body>
</html>
heatherdaw
Thank you so much Jon!  That did the trick.  Wish I'd posted my question much earlier.
JonathanUihlein
No problem! Feel free to make a new thread any time you have an issue.
While we don't have time to answer every single thread, I personally try to answer questions that are well-written and organized.
Also, attaching code is always appreciated 😄
