Change the Polygon width on ARCGIS Layers
1503
5
05-09-2014 08:35 AM
HelenAraya1
I want to change the polygon boundary width for my zipcode layers inside javascript API for ARCGIS.Does any one know on how I can do it?
I am using a rest webservice for the zipcode layers
Here is the code I use to get the zipcode layer on top of the base map.
var queryTask = new esri.tasks.QueryTask(USZipCodesURLREST);
   var query = new esri.tasks.Query();
   query.outFields = ['ZIP'];
   query.returnGeometry = true;
   query.outSpatialReference = $Guardian_Scripts_Application.$mapDiv.spatialReference;
   query.geometry = $Guardian_Scripts_Application.$mapDiv.extent;
   queryTask.execute(query, null, null);
JohnGravois
hi helen,
if you are passing the results of your query to a generic graphics layer, you can make the symbology anything you want.
new SimpleLineSymbol(style,color,width)
https://developers.arcgis.com/javascript/jsapi/simplelinesymbol-amd.html
when working with featureLayers, by default we inherit the symbology from the service itself, but you are able to override and set your own symbology on the clientside in that situation too.
FeatureLayer.setRenderer()
https://developers.arcgis.com/javascript/jsapi/featurelayer-amd.html#setrenderer
JohnGravois
hi helen,
HelenAraya1
hi helen,
Thanks a lot that worked for me!!!
JohnGravois
helen,
very glad to help.  when you have a moment, please consider marking this thread as 'answered'.
HelenAraya1
helen,
Can you let me know how I can set it answered. I am not sure how to do that.
JohnGravois
no worries, just click the �??check mark�?� icon on the right side of a helpful reply.
http://resources.arcgis.com/en/help/forums-mvp/
