Adding data inside of model builder
4019
01-03-2014 05:23 AM
MeredithGreen
I am building a model that fills out a table just like what is depicted in the jpeg file attached.  However, I need to add Summaries like what is highlighted at the bottom and sum everything up from above.  I am not sure how to do this in model builder as I have never done it before.  Is there a way?  Any help would be greatly appreciated.
[ATTACH=CONFIG]30213[/ATTACH]
JakeSkinner
Esri Esteemed Contributor
Hi Meredith,
You can run the Summary Statistics tool and then Append the results to the original table.
JasonJordan1
Hey Meredith,
I've just started recently using model builder so this may be the most inefficient way to go about it. What about a combination of the  spatial summary tool and the add join tool? so you run the spatial summary tool. It creates an output table, you then join that table back to your original table. Or maybe an Append (data management) tool instead of a join. Just append you summary output back to your desired target dataset.
Hope this helps and if not, eliminates some possible answers
cheers,
Jason
