Software development question related to ArcGIS JSAPI 3.4/3.5
1031
12-17-2013 09:24 PM
SunilPalkar
Hello All,
It might be very basic question regarding software development in ArcGIS JSAPI.
I have simple web page in which I am displaying map and below are the graph (Attached the screenshot with this mail. The graphs are static graph but I want dynamic graphs according to points/cluster in the specific area)
So is it possible to link between ArcGIS JSAPI and external graph? (D3 js used to draw the graph. So If I click on point on the map then that graph should be appear as shown in the screenshot.
I am not hard core developer and researched on Google/forum regarding this and not getting any information/sample so is it possible to link map data and external graphs ?
Any help/remarks will be great!!!
Thanks in advance : )
[ATTACH=CONFIG]29960[/ATTACH]
JonathanUihlein
Yes, you are able to use the same data set to generate both points on a map and graphs with d3.
There probably isn't an example using both ESRI JSAPI & D3 specifically but if you check out the documentation, you will be able to hook them up to the same data source.
