Attribute Inspector not showing Data
1478
11-05-2013 10:45 AM
NumaGremling
Hi everyone,
I am trying to use a sample and make it work with my data, but it seems that it will not fully recognize my layer.
Here is the sample I am using, and I have attached my code. I would assume that all I would have to do is change the feature layer and the outfields as well as the fields in the attribute inspector. Nothing shows up, however. When I click on my parcel the ???Click a geology outcrop to view details.??? will vanish, but the attribute inspector will not show up instead.
Any suggestions?
JasonZou
Javascript is case-sensitive. Based on the layer info, the objectid field should be OBJECTID.
Change:
selectQuery.objectIds = [e.graphic.attributes.objectid];
To:
selectQuery.objectIds = [e.graphic.attributes.OBJECTID];
JasonZou
Change:
To:
NumaGremling
Problem solved! Thank you so much!
