Hello evreyone:I'm programming a tool similar to ArcMap's Midpoint (Feature Constructor in Arcmap).I draw de line with a INewLineFeedback object and works well, but de mid point is well calculated, but doesn't refresh properly.i'm wondering if someone knows how i can resolve this....I attacht my code and a screenshot with the trouble.Thanks for your attention[ATTACH=CONFIG]28702[/ATTACH]
using System;
using System.Drawing;
using System.Runtime.InteropServices;
using ESRI.ArcGIS.ADF.BaseClasses;
using ESRI.ArcGIS.ADF.CATIDs;
using ESRI.ArcGIS.Controls;
using ESRI.ArcGIS.Carto;
using ESRI.ArcGIS.Display;
using ESRI.ArcGIS.Geometry;
using ESRI.ArcGIS.Geodatabase;
using System.Windows.Forms;
namespace Editor_Tools
/// <summary>
/// Summary description for Midpoint.
/// </summary>
[Guid("5a956a79-8872-4f48-aec9-5b048a307c31")]
[ClassInterface(ClassInterfaceType.None)]
[ProgId("EngineClassLibrary1.Midpoint")]
public sealed class Midpoint : BaseTool
#region COM Registration Function(s)
[ComRegisterFunction()]
[ComVisible(false)]
static void RegisterFunction(Type registerType)
// Required for ArcGIS Component Category Registrar support
ArcGISCategoryRegistration(registerType);
// TODO: Add any COM registration code here
[ComUnregisterFunction()]
[ComVisible(false)]
static void UnregisterFunction(Type registerType)
ArcGISCategoryUnregistration(registerType);
// TODO: Add any COM unregistration code here
#region ArcGIS Component Category Registrar generated code
/// <summary>
/// Required method for ArcGIS Component Category registration -
/// Do not modify the contents of this method with the code editor.
/// </summary>
private static void ArcGISCategoryRegistration(Type registerType)
string regKey = string.Format("HKEY_CLASSES_ROOT\\CLSID\\{{{0}}}", registerType.GUID);
ControlsCommands.Register(regKey);
/// <summary>
/// Required method for ArcGIS Component Category unregistration -
/// </summary>
private static void ArcGISCategoryUnregistration(Type registerType)
ControlsCommands.Unregister(regKey);
#endregion
#endregion
#region private members
private IHookHelper m_hookHelper;
private IEngineEditor engineEditor ;
private IEngineEditSketch engineEditSketch;
private IPoint midPoint;
private IPoint f;
private IPoint s;
private INewLineFeedback pFeedbackEnv;
#endregion
public Midpoint()
// TODO: Define values for the public properties
base.m_category = ""; //localizable text
base.m_caption = ""; //localizable text
base.m_message = ""; //localizable text
base.m_toolTip = "Mid point"; //localizable text
base.m_name = ""; //unique id, non-localizable (e.g. "MyCategory_MyTool")
try
// TODO: change resource name if necessary
string bitmapResourceName = GetType().Name + ".bmp";
base.m_bitmap = new Bitmap(GetType(), bitmapResourceName);
base.m_cursor = new System.Windows.Forms.Cursor(GetType(), GetType().Name + ".cur");
engineEditor = new EngineEditorClass();
engineEditSketch = engineEditor as IEngineEditSketch;
midPoint = new PointClass();
catch (Exception ex)
System.Diagnostics.Trace.WriteLine(ex.Message, "Invalid Bitmap");
#region Overridden Class Methods
/// <summary>
/// Occurs when this tool is created
/// </summary>
/// <param name="hook">Instance of the application</param>
public override void OnCreate(object hook)
if (m_hookHelper == null)
m_hookHelper = new HookHelperClass();
m_hookHelper.Hook = hook;
// TODO: Add Midpoint.OnCreate implementation
/// <summary>
/// Occurs when this tool is clicked
/// </summary>
public override void OnClick()
// TODO: Add Midpoint.OnClick implementation
public override void OnMouseDown(int Button, int Shift, int X, int Y)
// TODO: Add Midpoint.OnMouseDown implementation
IActiveView pActiveView;
IScreenDisplay pScreenDisplay;
pActiveView = m_hookHelper.ActiveView;//My.ArcMap.Document.FocusMap;
pScreenDisplay = pActiveView.ScreenDisplay;
IPoint pPoint = new PointClass();
pPoint.PutCoords(X, Y);
pPoint = Transforms.GetMapCoordinatesFromScreenCoordinates(pPoint, pActiveView);
if (pFeedbackEnv == null)
pFeedbackEnv = new NewLineFeedbackClass();
pFeedbackEnv.Display = pActiveView.ScreenDisplay;
pFeedbackEnv.Start(pPoint);
f = pPoint;
else
//pFeedbackEnv.AddPoint(pPoint);
s = pPoint;
double dx = (f.X + s.X) / 2;
double dy = (f.Y + s.Y) / 2;
midPoint.PutCoords(dx, dy);
engineEditSketch.AddPoint(midPoint, true);
pFeedbackEnv = null;
pActiveView.PartialRefresh(esriViewDrawPhase.esriViewAll, null, pActiveView.Extent);
//engineEditSketch.AddPoint(pPoint, true);
public override void OnMouseMove(int Button, int Shift, int X, int Y)
// TODO: Add Midpoint.OnMouseMove implementation
if (pFeedbackEnv != null)
pFeedbackEnv.MoveTo(pPoint);
s = pPoint;
double dx = (f.X + s.X)/2;
midPoint.PutCoords(dx,dy);
DrawPoint(pActiveView, midPoint);
public override void OnMouseUp(int Button, int Shift, int X, int Y)
// TODO: Add Midpoint.OnMouseUp implementation
public override void OnDblClick()
base.OnDblClick();
engineEditSketch.FinishSketch();
public override bool Enabled
get
if ((engineEditor.EditState == esriEngineEditState.esriEngineStateEditing))
return base.Enabled == true;
return base.Enabled == false;
#endregion
public void DrawPoint(ESRI.ArcGIS.Carto.IActiveView activeView, IPoint point)
if (activeView == null)
return;
ESRI.ArcGIS.Display.IScreenDisplay screenDisplay = activeView.ScreenDisplay;
// Constant
screenDisplay.StartDrawing(screenDisplay.hDC, (System.Int16)ESRI.ArcGIS.Display.esriScreenCache.esriNoScreenCache); // Explicit Cast
ESRI.ArcGIS.Display.ISimpleMarkerSymbol simpleMarkerSymbol = new ESRI.ArcGIS.Display.SimpleMarkerSymbolClass();
ESRI.ArcGIS.Display.ISymbol symbol = simpleMarkerSymbol as ESRI.ArcGIS.Display.ISymbol; // Dynamic Cast
screenDisplay.SetSymbol(symbol);
ESRI.ArcGIS.Display.IDisplayTransformation displayTransformation = screenDisplay.DisplayTransformation;
// x and y are in device coordinates
//ESRI.ArcGIS.Geometry.IPoint point = displayTransformation.ToMapPoint(x, y);
screenDisplay.DrawPoint(point);
screenDisplay.FinishDrawing();
//activeView.PartialRefresh(esriViewDrawPhase.esriViewNone , null, activeView.Extent);
