10.1 code that populates a field with sequential numbers
1844
09-18-2013 01:43 PM
ShikoNjuno
Hi folks,
I have a shapefile whose ID and FID numbers are all messed up in the attribute table and I'm looking for code I can type into my "Field Calculator" window that will fill in unique values for each polygon.
Any samples anyone?!!?! 🙂
Here's what I've tried so far:
[ATTACH=CONFIG]27562[/ATTACH]
The complete code is:
rec=0
def autoIncrement():
global rec
pStart = 1 #adjust start value, if req'd
pInterval = 1 #adjust interval value, if req'd
if (rec == 0):
  rec = pStart
else:
  rec = rec + pInterval
return rec
Anyone see any issues that might be causing this not to work?
The error msg I keep getting is the dreaded 99999 error. :confused:
by Anonymous User
Not applicable
You just need to make the expression with the parenthesis to execute the function.
autoIncrement()
by Anonymous User
Not applicable
autoIncrement()
ShikoNjuno
autoIncrement()
Yaaay.....little mistake.....huge difference!!!!
Thank you sooo much 😄
Cheers
